PST Carbon Fiber Driveshaft
I saw this driveshaft out at VMP. Anybody used this or know anything about it?
http://www.vmptuning.com/store/index...=392&parent=97 |
i think most people here use the shaft master's aluminum driveshaft. it weighs in at 18ish lb and is about half that price.
Originally Posted by f4ifrank
(Post 7110950)
Interesting. I was originally looking for a carbon fiber driveshaft, but couldnīt find a reliable one so I went with Shaftmasters. Great product though, so I canīt complain. 18.5lbs vs 38.8lbs, and even though I wasnīt a perfectionist with the install, no NVH at 120mph. I donīt know if an extra 3.5ish pounds could justify the extra 600$ on my budget.
What about Ron with his Spyder shafts??? I had one on my 06GT...It was a great piece!
how does the aftermarket alluminum or carbon fiber, d shafts help? smoother ride throughout all speeds and rpm's? any power gains to the distribution of wheels?
The lighter weight of the one piece shaft reduces the mass which has to be accelerated so the car accelerates faster. It does not make more power.
The problem is that because the engine is tilted trans down the alignment of the two Hook joints are never aligned correctly plus the sliding joint in the shaft allows the shaft to run crooked. And with slop this cause harmonics and vibration. The CV joint in the shaft linked above eliminates those problems plus it is lighter than other one piece shafts. |
I've driven my car up to 140 mph with my shaft masters aluminum drive shaft there is no vibration...
I had to get adjustable rear lower control arms to set the angle properly. It was vibrating at about 120 MPH, now it's fine.
I know this is an expensive piece, so I'm guessing nobody has used it?
