engine proplem help
Old Dec 5, 2010 | 12:32 PM
GEG's Avatar
GEG
Default engine proplem help
I have a 1996 Gt convert with 04 4.6. Its been a good swap with out any proplems until now. I was running at about 60 mpn when I lost power. After checking electrical plugs and fuses after which the car started. Sounded good and all of a sudden it sounded like it was loading up and quit. After sitting for about 10 min it started and by keeping the rpm up it ran about a couple of minutes and it loaded up. This went on for twenty miles until I was able to get to phone. I used a quarter tank of gas at this time. Could some one give a idea as to where to start looking. Ford does not want to touch it because of the engine swap as with most places. Thank you for time.
Old Dec 5, 2010 | 01:04 PM
jayed53's Avatar
jayed53
I would check the fuel filter/fuel pump as well as the fuse associated with the fuel system.
Old Dec 5, 2010 | 01:30 PM
SpartaPerformance's Avatar
SpartaPerformance
Any codes?
Old Dec 6, 2010 | 11:09 PM
GEG's Avatar
GEG
Default code
I don't have a way to check code. One shop wants $150.00 /$75.00 if they do repairs. Had no check engine light. My exhausts are black. I do have a small exhaust leak. When I turn the key on I can hear the pump come up and stall. Chilton tells me nothing. Where to look. I hate to pay to find out all it is is O2 or a air flow sensor. Where to look
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
