cai+tuner
You might want to check out the CAI/Tune packages from Brenspeed or American Muscle/Bama. They are the two top rated tune writers around these parts.
If you have a manual, you just need to use the tuner to adjust the gear ratio. IF you have an auto, you need an updated tune to change the shift points.
+1 on AM or Brenspeed. Don't be as concerned about the handheld as you are about who writes the tunes.
And the handheld should allow you to adjust for gear chnages and tire OD changes.
BartSimpson
Nov 11, 2007 05:58 PM
