New wheels....vibration
Old Nov 7, 2011 | 05:55 PM
Mayberry40's Avatar
Mayberry40
Default New wheels....vibration
I got new American Racing wheels and tires from NTB. The rims are torque thrust (chrome). I have had my stang back at NTB 4 times now for a mild vibration in the steering wheel and pedals over 60 mph. Now they are sending me to a local car dealership with a different type of wheel balance machine. Has anyone had this problem with American Racing torque thrust rims? Did I buy junk?
Old Nov 7, 2011 | 06:24 PM
Nuke's Avatar
Nuke
Did you make sure there are no rotor clips remaining on the wheel studs? Even one can be a source of vibration.
If it's not that, then a RoadForce balance is in order and then a good check of the suspension if THAT doesn't resolve it. The RoadForce will detect defects that go totally unnoticced with a typical spin balance.
Old Nov 14, 2011 | 12:08 AM
STANGmole's Avatar
STANGmole
It could be the tires as well.
Old Nov 14, 2011 | 07:47 PM
JCON's Avatar
JCON
I have AR Shelby Redlines with no vibration. Sounds like a bad balance/calibration. New shop/dealership for the next trip
Old Nov 15, 2011 | 08:39 PM
madmann26's Avatar
madmann26
A couple of things:
1. You are being sent to another place because NTB is using a crappy balance machine. More then likely, the place you are going will be using a Hunter GSP9700 balance machine.
2. ASK for a mixed weight balance. This is wear they use sticky weights on the inside of the wheel AND tack-on weights on the inside rim of the wheel only.
3. If there is still a balance problem or one or more of tires/wheels takes considerable more weight then others, ask them to rotate the tire 180 degrees and re-balance.
Old Nov 17, 2011 | 06:05 AM
JRC702's Avatar
JRC702
New wheels and tires really shouldn't need to be roadforce balanced.
In a nutshell, roadforce balancing allows a tire to be mounted on the rim in the optimal position so the imprefections in the roundness in the tire and wheel offset each other as much as possible.
I would expect a new tire and rim to not require roadforce balancing to address a vibration.
At our dealership often we use the results of roadforce balancing to confirm a tire is out of round and needs replacement.
Old Nov 17, 2011 | 06:40 PM
Mayberry40's Avatar
Mayberry40
Yesterday the rims/tires were balanced on a roadforce machine. They found 3 rims out of balance. So I took it on the highway and got a continuous vibration on the floor and gas pedal. Before the roadforce I had my steering wheel and floor vibrating.
NTB is looking into replacing the rims!
I have looked on the internet for good looking rims. It seems the good looking rims are replicas or made in China!!( The same as the AM torq thrust m's that are on my mustang now). I don't want the replicas..........
Does anyone have any idea where I can look for "quality" 5 spoke chrome wheels?
Old Nov 18, 2011 | 05:09 PM
madmann26's Avatar
madmann26
Did they do a run-out test on the wheels or did they rotate the tire? Those little red/yellow/green dots on the tire are there for a reason. I have FR500's from AM.com and they came balanced and I have had zero issues with them.
Did they roadforce test the tires? This is where they apply the top roller to the top of the tire and it can tell if something is wrong with the tire.
