Question about E-85
Old Sep 5, 2012 | 01:33 PM
cfr865's Avatar
cfr865
Default Question about E-85
I'm thinking about converting to E-85, just wondering if you are happy after doing this or wish you hadn't done it. Have you had any problems with anything failing after doing it .Also can you switch from E-85 to 93, if you have two different tunes. Has anyone done this ?
Old Sep 5, 2012 | 02:14 PM
Derf00's Avatar
Derf00
Gentleman's Relish
http://www.ethanol.org/index.php?id=81&parentid=25
I personally wouldn't since the Mustang is not an a certified FFV (Flexible Fuel Vehicle) but do what you will with the info from the link. I think the fact that if you put E85 in a car that is not a certified FFV that the manufaucturer won't cover damage under warranty says it all.
Old Sep 5, 2012 | 06:44 PM
SpartaPerformance's Avatar
SpartaPerformance
Do A LOT of research. converting to E-85 isn't as easy as some places suggest and you still nead to run a fuel additive every other tank or so of fuel, E-85 is hygroscopic.
Old Sep 5, 2012 | 10:22 PM
JCON's Avatar
JCON
need to make a decent number of changes to successfully run E85. Our cars are certainly not by nature FFV. I wouldn't bother. Did you buy a Mustang under the impression the gas mileage was higher?
Old Sep 5, 2012 | 10:30 PM
UberDuper's Avatar
UberDuper
E85 gives lower mpg. Quite a bit lower in my explorer I think.
Old Sep 5, 2012 | 11:01 PM
HxCGuitars's Avatar
HxCGuitars
My friend has a Saturn Ion that he converted to e85. Only thing he had to do was bigger injectors and a tune, also went with a smaller pulley making 18 lbs. And yes, he beat my car from a roll. I'm hopeful with longtubes, but we'll see.
He runs no fuel additives. I'm sure there's a good amount that has to be considered when running e85, but just do some research or call up a local performance shop.
Judging by OP's signature he's not worrying about "warranty" and isn't looking to switch to it like a flex fuel vehicle, but rather performance.....e85 has an octane similar to race gas. Smells good too.
Old Sep 6, 2012 | 12:18 AM
Simon1's Avatar
Simon1
You would need to go to a return style system. Not 100% sure but unless you have a built motor and a blower, keep it as it is.
If you would like something for the track, get a 100 octane tune.
Old Sep 6, 2012 | 08:12 PM
SpartaPerformance
E-85 burns 20% less efficient then gasoline
Old Sep 6, 2012 | 08:27 PM
Entaille's Avatar
Entaille
random input: my only experience with e85 is for the turbo 4 banger guys - a friend with an evo 9 made 430whp on e85 and retuned to get back onto pump gas and makes around 385whp now ..
e85 is inconvenient for a lot of locations - there's not a ton of stations for most areas, and you go through it quicker. it can make some power, though.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
