electrical issue?
Old Apr 14, 2015 | 08:49 AM
dbirdrm's Avatar
dbirdrm
Default electrical issue?
Turned out to be nothing
Old Apr 14, 2015 | 09:39 AM
jwog666's Avatar
jwog666
check for loose connections at the headlight grounds and switch, most likely the jolt of the shift s causing the loose connection to go open
Old Apr 14, 2015 | 07:02 PM
dbirdrm's Avatar
dbirdrm
So i just changed the headlight bulbs and they are working now. Something had to cause both high beam lights to blow out at the same time I can't seem to figure out what it is tho.
Old Apr 14, 2015 | 11:24 PM
cruisin5268d's Avatar
cruisin5268d
Sounds like a possible cabling issue. Maybe a gunked up or loose connector.
chrisdbassplayer
Oct 13, 2015 06:53 PM
Dathan
Oct 5, 2015 05:52 AM
LiquidDrink
Sep 29, 2015 10:06 AM
mrappe
Sep 26, 2015 10:16 AM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
