Shift indicator
Old Jul 24, 2017 | 09:34 PM
Red Bear's Avatar
Red Bear
Talking Shift indicator
Had a problem with the shift indicator and found in my research that I'm not the only one. The most solutions I found said something about poking a hole in it and threading a small wire through the two pieces. I didn't really like that idea so I tried one of my own. Instead I took a small wire brush to scuff up the two pieces and then I supper glued them. Then to strengthen the bond I heated the end of a cheep flat head screw driver and "melted" the two together by rapidly dragging it across the bonded area. Had to reheat the screw driver a few times but it worked great. Hope someone can use this.
