2006 mustang GT. Idles but dies when throttle is touched
Old Aug 21, 2021 | 12:22 PM
Yeagerbombs7's Avatar
Yeagerbombs7
Default 2006 mustang GT. Idles but dies when throttle is touched
I'm really scratching my head here. I put the car back together with new cams. Verified the timing. The car seems to idle pretty well, but the throttle is like a kill switch. The car sat for a year or two. I added new fuel, a can of seafoam, and a new fuel filter last year while it was under construction. I'm not sure where to start or how to test. No codes, pretty sure all grounds are good.
I took the air intake off to verify that the throttle body was opening and closing. I also cleaned it.
I'm wondering if it could be the throttle body or fuel pump, but would it idle fine and die with throttle if that were the case?
Edit: I just installed a new throttle position sensor. Car started up, hunted a little between 800 and 2000, still dies if throttle is touched.
Codes: P0135/ P0155 for 02 sensors
P1000
Old Aug 24, 2021 | 03:36 PM
nulizio's Avatar
nulizio
Where did you get the tune for the cams from? Does it have any trouble starting? And did you data log at all? Mine behaved similarly after I put Ford Performance Hot Rod cams in it and it was a tune issue. Also, having the upstream O2 sensors unplugged can make the computer upset sometimes.
Old Sep 21, 2021 | 04:35 PM
Yeagerbombs7
Thanks for the response. Work took me out for a while but I'm back at this project.
The cams are Detroit rockers from the manufacturer. The tune is a bama tune.. I'll admit,, I did look under the car and believe the upstream and downstream O2s looked switched. Right now I would like to data log and contact bama. I'm hoping this is not a timing issue of some sort.
JayStarWind
Sep 22, 2019 06:31 PM
Grinder4400
Jun 1, 2016 09:28 PM
RlovellGT
Feb 17, 2015 08:54 AM
mmeals
Jul 30, 2013 06:05 PM
TURBOGREEK
Oct 3, 2011 07:33 PM
