HELP!! Fuel Pump fuse
Old Mar 9, 2022 | 12:33 PM
Anon45's Avatar
Anon45
Default HELP!! Fuel Pump fuse
My car has been down for weeks now! My fuel pump fuse is continuously blowing. It has a short on the constant power side. I have checked every wire, every ground and even the entire fuse box. Nothing has been found. Any ideas?
  • Fuel pumps are good
  • Grounds are good
  • sensors are good
  • wiring connections look to be good
  • all other fuses are good
HELP!!!
Old Mar 12, 2022 | 01:20 AM
bl817's Avatar
bl817
Ford Workshop Service & Repair Manuals - fordrepair.info Home (iihs.net)
this is all i got for now, you can search at your leisure. i couldnt find a dedicated diagram for the fuel pumps, it should be there tho. good luck
Old Mar 12, 2022 | 05:45 AM
Anon45's Avatar
Anon45
Default Solved
Thank you! I actually solved it! It was a pinched wire on the fuel injector connector. Bought a new connector and it’s been running since!
Old Mar 15, 2022 | 01:09 AM
bl817's Avatar
bl817
Word, good fix!
Gulden69
Mar 31, 2013 10:52 PM
VistaGT
Jan 8, 2011 11:49 AM
5.0kid
Mar 16, 2009 05:42 PM
tydirium
Jun 9, 2006 02:54 PM
02bluev6
Jun 2, 2006 02:36 PM
