4 Cylinder General Discussion For non tech 4 Cylinder owner chit chat
That light?
Old Nov 7, 2007 | 06:41 PM
marioso28's Avatar
marioso28
Default That light?
What is the correct name or does it have a correct name, of the light on the top of the headliner, closest to the windshield and the rear-view mirror? I need a bulb for that and cannot find the name of the light nor the bulb size at any auto shop. Any one have the bulb size or know any info on it?
Old Nov 7, 2007 | 07:19 PM
sleeper_inc's Avatar
sleeper_inc
Default RE: That light?
The MAP light?
I just used a lightbulb from a side marker on a 83 1500 GMC
Old Nov 7, 2007 | 09:18 PM
marioso28's Avatar
marioso28
MAP light!! Okay, I'll try that if not a side marker for an 83 GMC 1500 will work? Good to know. No one at the auto parts knew the name of it so it was hard to look up.
Old Nov 7, 2007 | 09:22 PM
mg man 75's Avatar
mg man 75
Correct and it still probably won't work. Removed several out of junk cars none work. The switch in it corrodes. There is a plastic cap over it on backside take a dremel tool and remove the melted over plastic. Not too much. Then dismantle and clean the copper contacts. Reassemble and remelt plastic over with soldering gun. Works. Now to find time to paint the one I fixed.[red] and replace the black one in my car. Oh well I guess I can fix it also.
Old Nov 7, 2007 | 09:24 PM
92lxsleeper's Avatar
92lxsleeper
the map lights are the two outer ones, the center light is a dome light.
Old Nov 7, 2007 | 09:29 PM
marioso28's Avatar
marioso28
I see.... I did not see a lot of corrsion or anything in the light, it looked just fine. But I will double check.
Old Nov 7, 2007 | 10:13 PM
924banger's Avatar
924banger
http://www.sylvania.com/ConsumerProd...RG-Results.htm
That should help. Has every light on the car, and some of those you can switch out for LEDs to help the battery out a little. I am thinking about going full LED except headlights so that when I get a radio and sound system my accessories won't pulse at idle...hate that.
Old Nov 7, 2007 | 11:00 PM
Jugador's Avatar
Jugador
us sunroof guys are lucky, we don't have map lights
Old Nov 8, 2007 | 08:54 AM
92lxsleeper
ORIGINAL: Jugador
you dont even have them on the rear view mirror[&:]
Old Nov 8, 2007 | 02:15 PM
Stang2.3's Avatar
Stang2.3
Nope we only got a Dome light. about a fist in front of the Sunroof lol
