instrument breakdown question
My dash lights came in(day 8)!!! Now I just have to put them in. How do I get the face off???? The part that holds the headlight switch!! I have 4 bolts out, but I think I have to take the plastic around the steering wheel off to? How do I do that? Please help fast as I am trying to do this before the sun does down or close after. Thanks in advance!!!!!!
John
John
Anything under the steering wheel has to come off and even that thing that goes on the coloum for looks, then you have to unplug all the conections in there. I can take pictures if you want
I AM NOT HAPPY[:@][:@][:@]. Well Stupid me put the dash back together before I tested the lights. I did that cause I didn't want to upset the airbag. I turn the lights on....the are really dark, I think I might need super intense leds. I can't see me fuel and oil pressure needles, my left turn signal won't light up(I replaced the turn signals, the right side looks good), and themilage is hard to see. That is with the dimmer as highas it will go without turning the cargo light on. ARRRRGGGHHHH!!!!!!! I will see if besthongkong.com has any super intense. Here is a pic....I shows up a lot brighterin the pic.
I would have looked good if it was not that dark. You should just take the original bulbs and buy some of that blue tint paint and cover them then re-install
If you do get some don't get the ones that I first bought. You can hardly see anything with them. I can't even see my fuel, part of my speed, engine temp, and oil pressure. I have ordered some different bulbs, so I'll see if they make a difference.
Superbrightleds.com is exspensive, but you get a bigger varietyof bulbs to choose from.
. I may look into getting something like that for mine.
