Engine Swaps
Man...i thought there would be a little more knowledge about Marks on here..
Anyways, the spindles, rotors, and brakes will fit, but you need a ball joint spacer, since the Mark uses a different balljoint than the rest of the fox's. Maximum Motorsports sells them. You can swap the entire rear if you want, but i wouldnt do it. They are 1.25" wider per side than your mustang, which would make the wheels hang out big time.
If you do the 5-lug swap, youre still limited to which wheels you run due to the hube and dust caps on the Mark rotors. I did the Mark swap in my TC, and am limited to mostly stock wheels.
The 95 3.8L made 140 horsepower.
1 1/4 wider doesnt sound too bad, no show car just want it to go ... faster and stop better. I would just stick with the mark rims they are 16 by 7. What is a ball joint spacer like?
I think due to the width difference in the rear end im going to stay with the 4 bolt wheels for now, and keep all the parts from the mark7 for another time maybe, but I just found out the 5.0 from the mark7 is going in my fox!
Watch out on those 5.0 mark. I told a friend of a lincoln found in a cheap junkyard. He was not interested because he said it was a low hp 5.0. He said one of best 5.0 is a 5.0 in explorer with gt40 head. Big intake and exhause ports. Do some research on hp on that year. Hate to see you regret it after all the hard work
ORIGINAL: mg man 75
