4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
engine problems
Old Jul 12, 2007 | 02:54 PM
mustube's Avatar
mustube
Default engine problems
my grandpa has just boughta 1990 convertible mustang with the 2.3 w/ automatic trans, it was in a minor front end collision and the engine doesnt run good at all,its a sometimer, sometimes it idles good, and sometimes it dies in gear, sometimes it smokes alot andsometimes theres no smoke at all... it doesnt seem to matter what temperature the engine is at. And it doesntseem to be firing on all cylinders. We unplugged the MAF sensor and itdidnt change anything, could the sensor be bad? I think the plug wiresneed to be changed to but I dont know anything about the ignition system on this car, im used to my66 straight 6. any help would be greatly apprectated.
Old Jul 14, 2007 | 02:42 PM
mg man 75's Avatar
mg man 75
Default RE: engine problems
Run codes on computer. Good tuneup. Check for vacumn lines off, Maybe a broken "t" in vacumn lines.Maybe cracked distributor cap. Look for maybe a wireconnection on motor loose or broken. How old is fuel filter. Wreck could have strirred up some junk in gastank and plugged it. Best ideas i got for now.
Old Jul 14, 2007 | 08:16 PM
bacon57's Avatar
bacon57
ByMAF youmeant mass air flow meter right?If thats what you mean you didn't unplug it on a1990 2.3.The 2.3 engine did not get a mass air systemuntill they got the dual plug head in'91. I would check the distributercap first.
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
HIS S-197
Aug 10, 2015 05:47 PM
Pain.
Aug 7, 2015 10:48 PM
