4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
egr problems
Old May 8, 2008 | 11:58 PM
usermst9673's Avatar
usermst9673
Default egr problems
So i had what sounded like a bad idle, possibly missing and decided to pull the vaccum hose on the egr valve as soon as i did it idled way better. Is the valve bad, or is it something else with the egr system. Give me your opinions please and if you have any tips on how to figure it out please let me know thx.
Old May 9, 2008 | 08:31 AM
sleeper_inc's Avatar
sleeper_inc
Default RE: egr problems
Clean your EGR valve. Its probably gummed up with all kindas of ****.
Also did you plug the vacuum line when you took it off?
Old May 9, 2008 | 02:34 PM
usermst9673
no i just took it off temporarilly. Does the valve open when there is vaccum or when there is not? Ill take it off later today and clean it though and see if it makes a difference, i doubt its ever been cleaned and has 161,000 miles on it
Old May 10, 2008 | 01:08 AM
sleeper_inc
The valve opens when there is vacuum
Old May 10, 2008 | 04:43 AM
usermst9673
so i am assuming the vaccum line should not be pulling vaccum at idle correct? cause the idles horrible with it connected to the egr and i know its pulling vaccum. I tried cleaning the egr and it didnt look too bad, no difference in idle condition.
Old May 10, 2008 | 09:20 AM
sleeper_inc
Check to see if your EGR controls (back side of the passenger strut tower) are open or closed. If there open try replacing them with a JY unit
Old May 11, 2008 | 03:08 AM
usermst9673
turned out to be the bad part!!!! Got a new one from the jy for $5 bucks. Runs perfect now. thx for the info man!
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
TfcCDR
Sep 14, 2015 12:08 PM
