part yard run
Unmolested turbo coupe? I find it hard to believe the engine wasn't blown if the body was in decent shape. Still ,that's not a bad find at all. You should grab the rear axle if you can - 8.8 with disc breaks and it's 4-lug. If it's an auto it probably has 3.73's in it too. We got a yard around here with 2000+ cars in it. And a lemonade stand, and three rest points. It's pretty much amazing.
Good score though. I jsut found much the same, got the VAM and processor out of it. I never though about the seats though, maybe i'll go back...
I may go back for the rear end and disk brakes, If it's still there. Btw, it is a manual. I do want the disk brakes if they just swap in, especially since my drums are in sore condition.
On a seperate note, I'm turning my old seats into desk chairs (I'm too cheap to buy one). I'm not exactly doing a professional job on it, just mounting it to a board that I'm mounting to legs. I'm strange, I know, but I'm okay with it.
Haha. The axle assembly will just bolt up. It's posi'd too. It's 3/4 inch longer on each side, so I'm not sure if you could just grab the axle shafts. There is a write up on stinger performance.
Cool. Now I NEED a truck. I've been using my mom's subaru and it just isn't big enough for a rear end (or an engine if I can get one), unless I remove the axle tubes etc first. Then it'll get the nice interior dirty. Maybe I'll buy an old beater truck for part runs.
ORIGINAL: icelandismine
May want to grab the big vam,wire connector, and vam hose.and computer. Leave the air cleaner no one wants it. Since 5-speed has the la-3 all turbofords want. Look at label on computer. Hey Sleeper-inc do you still need those items? May want to PM him. Even if motor is bad, What they charge for a motor worth it as a rebuildable core. Headgasket is I would say 90% of failure and that is no big deal. Can rent or borrow truck from freind. Most car lots will rent a truck. Especially a older truck. Don't want to skin up a newer one.
