4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
black smoke?
Old Jun 26, 2008 | 09:10 PM
alboy91lx's Avatar
alboy91lx
Default black smoke?
So i guess whenever in flooring it and am at higher rpm there is visable black smoke coming out the back... my friend told me this and i made him switch cars so i could see this... only at 4,000 rom and above it shows visable black smoke... any ideas? The mechanic at my works says it may be the cam timing... so i tried to do the cam timing and there is no mark to line it up to on the cam side... wtf? any idea's?
Old Jun 26, 2008 | 09:53 PM
92lxsleeper's Avatar
92lxsleeper
Default RE: black smoke?
try some seafoam, and if thats not it. try cleaning your injectors
Old Jun 26, 2008 | 10:16 PM
sleeper_inc's Avatar
sleeper_inc
Black mean rich. Pull codes.
Old Jun 26, 2008 | 11:09 PM
92lxsleeper
if its rich. then you only have so many things that could be wrong.
1. maf
2. O2
3. injector is not closing completly at high rpms possibly
also... pull your spark plugs and check them. checking them are as good as pulling codes sometimes
Old Jun 27, 2008 | 01:26 AM
alboy91lx's Avatar
alboy91lx
did seafoam the other day in the walmart parking lot...lolback when i checked the codes there was somthing about the maf and o2i think... like a 186 and the 172... is it worth replacing that ****? spark plug are about 3 weeks old...
Old Jun 27, 2008 | 10:03 AM
sleeper_inc
MAF measures air into the engine, o2 keeps track of your A/F ratio on the hwy. Making sure both work will give you better gas mileage and drivability
Old Jun 27, 2008 | 10:09 AM
icelandismine's Avatar
icelandismine
Pull the MAF sensor out of the airbox, and spray it down with carb cleaner. Near the sensor wires, and on them, there will likely be a bunch of crap and build up. Take a small screwdriver or pick and CAREFULLY clean it off.
O2 might just be best to replace.
If you can't find your cam timing mark, then you need to go around on the crankshaft one more time.
Old Jun 27, 2008 | 10:19 AM
sleeper_inc
ORIGINAL: icelandismine
NO!!!!!!!!!!!!!!!!!! DO NOT DO THIS!!!!!!!!!!!!!!!!!! it destroys the sensors sensativity and it will fail very soon. Just buy MAF cleaner, its the same price as carb cleaner
Old Jun 27, 2008 | 12:13 PM
icelandismine
Huh? Never had any issues on it before, though to be fair, I use breaklean...what do you think the ford mechanics do?
Old Jun 27, 2008 | 01:54 PM
sleeper_inc
They use it, but if it fails because it was cleaned like that, don't think the place you bought it from would give you another one. They will say it was your fault and NEvER give you a refund or even another one.
Stay with the stuff that works. I've used it all to clean my parts, and by far the best I've used is the cleaner made for doing it... but hey, who knows.
