4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
Codes
Old Jul 3, 2008 | 05:58 PM
92lxsleeper's Avatar
92lxsleeper
Default Codes
just so everyone knows. autozone sells a OBDI code puller for ford vehicles for $29.99.
Old Jul 3, 2008 | 06:45 PM
sleeper_inc's Avatar
sleeper_inc
Default RE: Codes
I have one that I bought for $2.00... It's called a piece of wire and a ground light... Works perfect
Old Jul 3, 2008 | 08:26 PM
92lxsleeper
Default RE: Codes
ORIGINAL: sleeper_inc
yea well... all you do on this one is plug it in[8D]
plus.... i can post ads on craigslist saying that i'll pull codes for $10.00
garages charge 30-100 for this
Old Jul 3, 2008 | 09:19 PM
dreamer1uk's Avatar
dreamer1uk
Default RE: Codes
ORIGINAL: 92lxsleeper
Or!!!!
Autozone can read the codes for free!
Old Jul 3, 2008 | 09:40 PM
92lxsleeper
Default RE: Codes
ORIGINAL: dreamer1uk
Or!!!!
only OBD II vehicles[8D] 1996 and up
Old Jul 3, 2008 | 10:13 PM
sleeper_inc
Default RE: Codes
I have mine set up so I have a quick connect to the wires, and a test light. Takes 10 seconds to connect, the OBD I scanner takes 5 seconds...
Old Jul 3, 2008 | 11:02 PM
92lxsleeper
Default RE: Codes
do the OBD I scanners only work when the check engine light is on?
Old Jul 3, 2008 | 11:40 PM
sleeper_inc
Default RE: Codes
No, they should report a code #11 for normal (no codes) or the codes...
Old Jul 4, 2008 | 10:26 AM
92lxsleeper
Default RE: Codes
cause my check engine light comes on while driving. i'm thinking its either the o2 sensor or the EGR. i'm leaning more towards the EGR, because the o2 sensor would give me bad fuel mileage, and filled up yesterday and am now getting 18 in the city.
Old Jul 4, 2008 | 10:30 AM
sleeper_inc
Default RE: Codes
the computer goes off fuel maps inside it till you reach 45-50 MPH, then it will swap over to the o2 when cruising. Could be an o2, ECT, etc.
