Pulled codes today, need awnsers
OK here are the two codes i pulled today.
327 was pulled in KOEO AND KOER - EVP/EPT circuit below minimum voltage
538 was pulled in KOER - Insufficient RPM change during KOER dynamic response test.
538 is also labled - (Trucks ONLY) invalid cylinder balance test due to throttle movement during test.
So i know i need a new EGR valve position sensor (prolly one at junkyard, unless its cheap at autozone.)
whats the problem with 538? anyone know what i need to buy?
ok i solved the 538. i didn't press the accelerator manually during the dynamic test.[:@] stupid me for not reading the instructions[8D]
all i need is a EVP sensor. (EGR Vacuum Pressure)
yup. 1 $60.00 part to buy on friday[8D]
but after that, i will read a code 11 - all systems normal
i even ran a cylinder balance test, and i have good compression, and all 6 injectors are working perfectly.
when you start the KOER test, the first code was "6" for me, since i have 6 cylinders. after that, you get a code "10" at that point you press the accelerator 1/4 way down and release very fast. then you just let it do its thing.
and after that i got a code "90" all cylinders passed. if i got a "10" then cylinder 1 wasn't working right "20" for cylinder 2, and so forth and so forth.
TfcCDR
Sep 14, 2015 12:08 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
zanemoseley
Sep 6, 2015 12:58 PM
