NPR intercooler install
ok well i been lookin up intercooler installs but it seems i cant find any NPR intercooler installs i have a 26 core intercooler but i dont know what exactly is needed to make it fit or what exactly i gotta do to get it in there i was hoping to keep my A/C but if i cant o well just trying to find someone who done did it and what they did and everything so i will know how to do it and now screw anything up lol
figured there be no way in hell i could keep my stock Radiator o well... and where do u find this Afco Radiator at i wanna price it.... what about a Ranger Radiator i can get a new one for 89 dollars off ebay with free shipping what years will work and can it work with keepin my AC like this afco one?
It's a custom application so pretty much any radiator will work as long as the total width is kept inside the NPR inlet and outlet tubes. A Ranger rad will work. Your stock Mustang rad may work also. Break out the tape measure! You're gonna have to figure out some brackets but all you'll need to make them is a hacksaw, drill, vise and big hammer! I've included some pics of my install. '89 Mustang w/big NPR, rad out of an '89 Volvo and '90 SuperCoupe fan.
Pic #1 is the way I initially mounted the setup. I didn't like it so I remounted it later. The initial mounting places the whole setup inside the core support in the engine compartment, much like the writeup above. I however, don't run A/C so I decided to remount the setup back a couple of inches.
Here's some of the mounts I fabbed initially (yuck!)
I eventually moved it back where the NPR actually sits inside the cradle of the core support and the bottom extends outside a bit. Consequently, the NPR rests at a very slight angle. Doesn't interfere with performance or looks one bit. And, it looks like an A/C condenser may fit between the NPR and the big bumper bracket also.
Here's a view from the other side. Note the mounting brackets (green arrows). All made from bar stock. A couple had to be bent 90*, that's where the vise and big hammer come in. No welding, all bolt in! All in all, a pretty easy install. Look everything over real good, get an idea in your head, take some measurements and go for it!
will this radiator be a good choice i can get it for 70$ should work and be able to keep my ac wouldnt it?
http://cgi.ebay.com/ebaymotors/85-94...Q5fAccessories
http://cgi.ebay.com/ebaymotors/1985-...Q5fAccessories
Which one would be better you think ?
The second one has funky outlets. Will either of those even fit? I saw 18" for the core. Add a couple of inches on each side for the tanks. The distance between the NPR outlets is 23". If it doesn't fit, you're gonna have to send it back.........shipping costs. You're gonna have to modify it and fab mounts too.
As stated before, go to the 'yard and find one that'll fit with the proper outlets, sizing, etc. You can always take it to a rad shop and have it tanked. A lot of times junkyard cars have new parts on them. My Volvo rad came with an overflow tank, hose, brackets and all nuts and bolts. It looked brand new and the inside was squeaky clean. It was obviously a factory replacement that was maybe a month old - $20.
Have you measured your Mustang rad? I know the Volvo fits nicely although it's a closed system. You have to mount the overflow/fill tank above the rad coolant level. A tape measure is your friend.
Sep 10, 2015 08:39 PM
