4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
a couple of problems.
Old May 6, 2009 | 09:34 PM
ExtrmZ's Avatar
ExtrmZ
Default a couple of problems.
I am leaking transmission fluid from the connector on the line that goes to the radiator. The connection is tight, but the tube wiggles inside the connector. Is there some sort of o-ring in there that can be switched out? or what is the best way to fix this leak?
There is a high pitched whine coming from what looks like a fuel regulator on the rail. Its the one towards the back of the car. This whine goes away when the car is accelerating, but comes back when it is idling. Could this problem be linked to a bad fuel pump?
Old May 7, 2009 | 12:00 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
pull the vacuum hose on the regulator and see if theres fuel or if you smell fuel(might have a ruptured diaphragm
theres no o-ring maybe you have something stuck in there(trash etc)
Old May 7, 2009 | 11:27 AM
ExtrmZ's Avatar
ExtrmZ
im tallking about the one on the back of the rail, there is no vacuum hose going to this one. Is it a regulator? i dont know what else it could be
Old May 8, 2009 | 09:28 AM
trashline's Avatar
trashline
It is a fuel dampner then can go bad.
As for the trans line, you are probably just better off replacing the entire thing then trying to reflare the end.
Old May 9, 2009 | 10:57 AM
ExtrmZ's Avatar
ExtrmZ
i dont think the line flares out. or at lease to where i could see it.
Old May 11, 2009 | 01:37 PM
trashline's Avatar
trashline
you wont see the flare from the outside it will be inside the fitting. It is kinda like a brake line. Unless it is something different.
CS2007
Jun 25, 2019 09:45 PM
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
ChampInSD
Oct 2, 2015 04:55 AM
