4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
93 2.3 no injector pulse
Old Oct 26, 2010 | 08:33 PM
steveh's Avatar
steveh
Default 93 2.3 no injector pulse
heres what i got,93 lx idling,cuts off and now wont restart,got fire to the dis,can spray carb cleaner in the air tube and it runs,got 12 volts on the injector red wire,put noid light on plug,no pulsing,replaced the pcm with used one,still no run,any help!!!!!!!!!!!
Old Oct 29, 2010 | 02:58 AM
Babybudistmonk's Avatar
Babybudistmonk
is this a new problem or did you buy it this way?
Are there any other electrical issues with the car?
Old Oct 30, 2010 | 07:17 AM
steveh's Avatar
steveh
new problem,i just replaced the crank sensor,now i get one flash out my noid lite when i first spin it over,had ign check mwas ok,this thing is driving me nuts!
Old Nov 17, 2010 | 11:03 PM
dreamer1uk's Avatar
dreamer1uk
Did you take alook at the timing belt? CEL light on?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Dathan
Oct 5, 2015 05:52 AM
MacSerio
Sep 27, 2015 01:05 PM
pimp2303
Sep 17, 2015 08:45 PM
