4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
2.3l needs help
Old Apr 3, 2011 | 06:43 PM
92LXNewbie's Avatar
92LXNewbie
Default 2.3l needs help
I have a 92 lx hatch, and I'm having 2 problems with it. The first is that sometimes when I hit the gas, from a stand still, I majorly lose power, until I completely mash the accelerator, then it jumps to and gets movin'. Second my gas mileage sucks, I'm going through half a tank a week, driving around 20-30 miles, and my highway gas mileage is just as bad. I'm new to mustangs but I figured it being a 4-cyl it should get better gas mileage than that. Any ideas on what I can do to fix either of them would be appreciated.
Old Apr 6, 2011 | 03:32 PM
Babybudistmonk's Avatar
Babybudistmonk
Back probe your TPS with a multimeter. Make sure there are no dead spots in the voltage output as you open and close the throttle, and that its sending the correct voltage. Sounds like a similar problem I had a while back.
Is the check engine light on?
Old Apr 8, 2011 | 12:59 PM
7_Zero's Avatar
7_Zero
I agree with babymonk, sounds like your TPS needs to be adjusted. I have to adjust mine every couple of months to avoid the wandering idle and major bog down at acceleration. Adjusting this should also help improve your mileage as well. Stinger has a good write up on his web site.
Old Apr 8, 2011 | 09:13 PM
92LXNewbie's Avatar
92LXNewbie
Thanks for the link. I could do that if my RPM gauge worked. And yes the check engine light is on, most of the time.
Old Apr 9, 2011 | 03:10 PM
Babybudistmonk
So what codes is it throwing?
Old Apr 9, 2011 | 07:48 PM
92LXNewbie's Avatar
92LXNewbie
Weird thing is when I borrowed the tester from my local O' Reilly's, formerly know as schucks, it didn't give me any except for a short that I believe I fixed when I replaced my spark plug wires.
Old May 10, 2011 | 12:18 AM
92LXNewbie's Avatar
92LXNewbie
So a friend of mine suggested something and I thought I'd run it by ya'll see what you think, and I need helping finding the right part, but he suggested that it might be my fuel pump or the fuel system. I had the idea that it might be a partially clogged fuel filter. Are either of these a possibility? If it is the fuel pump what should I get to replace it?
Old May 10, 2011 | 01:29 PM
Babybudistmonk
If its never been changed, then yes change the fuel filter.
As far as your symptoms go, I really don't think It will change much.
Go someplace that knows how to do both KOEO and KOER EEC-IV diagnostic testing. With symptoms this bad you should be getting codes related to the issue, especially if your CEL is on.
Did you check your TPS yet? You dont need your tach to check it, just a multimeter.
jlopret
2.3L Eco-Boost Tech
Nov 19, 2015 10:32 AM
ShaneB26154
Aug 28, 2015 04:47 PM
Pyre
Dec 23, 2005 01:36 AM
tommyboy1989
Jun 21, 2004 02:21 PM
