what else do i need
ive got about a week before my heads arrive, i was wondering what else i may need to buy so i can install these on my 83 motor with as much ease as possible. this is a list of everything that comes with the heads
Basic Package Components:
100% CNC Ported Combustion Chambers
100% CNC Ported Exhaust Ports
100% CNC Ported Intake Ports
Competition 3-angle Valve Job
Intake Valve, 2.020” stud mount, AFR #72060
Exhaust Valve, 1.600” stud mount 58cc, AFR #7219
Exhaust Valve, 1.600” stud mount 61cc, AFR #7220
Intake Valve, 1.900 Pedestal, AFR #7201
Exhaust Valve, 1.600 Pedestal, AFR #7226
1.450” OD Hydraulic Dual Valve Spring with dampner, 120 lbs. on seat, .550” maximum lift (upgrades available), AFR #8020
10� Chrome Moly Retainers, AFR #8510
10� Valve Locks, AFR #9005
3/8” Rocker Studs, AFR #6410
5/16” Guide Plates, AFR #6107
Valve Seals, AFR #6611
Hardened Shims, AFR #6326
Intake Valve Seats, AFR #9058
Exhaust Valve Seats, AFR #9069
Bronze Valve Guides, AFR #9049
Thermactor Air Injector, AFR #6226
Special orders available upon request
All Accessory Holes are Predrilled & Tapped!
Specifications, Features, and Supporting Components:
Head Torque 65-70 Ft. Lbs. with 7/16” stud
Rocker Stud Torque 55-60 Ft. Lbs.
Rocker Pedestal Torque 25-30 Ft. Lbs.
Intake Port Gasket, 1.200”x2.000” w/ 3/8" radius, AFR #6828
Exhaust Port Gasket Fel Pro #1415, AFR #6837
Head Gasket 1962-82, Fel Pro #1011-1, AFR #6808
1983-93Fel Pro #1011-2, AFR #6809
Head Bolts & Studs Standard ARP, AFR #6323 & #6322
Head Bolt Washers Manley, AFR #6320
Stud Girdle Standard
Suggested Manifold RPM Performer, Performer
Spark Plug Starting Range Autolite 3924
Combustion Chambers 58cc or 61cc
Spring Pocket can be cut to 1.625, no deeper.
Valve Spacing Standard
Rocker Arms Standard, will not accept rail rocker arms
Valve Angle Standard
Angle Mill (10cc Maximum Mill) .008” per cc
Flat Mill (4cc Maximum Mill) .006” per cc
ORIGINAL: 88BlueGT
You should just start tearing down your motor a day or two before you get the heads so when you get them you can just throw them on and put it back together.
I would change over your timing chain to a double roller. I would also replace your lifters. It they are stock, definatly. Make sure you follow the directions, I think if I remember correctly you have to soak them in oil before you install them.
ORIGINAL: Mustang#2
the engine, for the most part, is stock, but its a remanufactured one, put in a year ago. were you saying to change them because the factory lifters are inadequate, or because they might have been worn out due to age¿
do i have a mechanical or hydraulic flat tappet¿¿
does the double roller timing chain run on a non roller block¿
thanks
