Fox AOD transmissions
Old Mar 5, 2006 | 05:06 AM
FoxGT's Avatar
FoxGT
Default Fox AOD transmissions
Was there a difference in the AODs from 79-93? I found an '83 3.8L Mustang with an AOD in it. I'm curious... is the transmission just as strong as my '88 AOD. & what about the gearing.
Old Mar 5, 2006 | 05:18 AM
grabbem88's Avatar
grabbem88
Default RE: Fox AOD transmissions
the flexplate is probably diff..converter will probably be junk...
Old Mar 5, 2006 | 09:34 AM
lookinforastang's Avatar
lookinforastang
I ♥ Acer
its weaker
also has 7.5 rearend instead of 8.8 so driveshaft might to be replaced not sure
Old Mar 5, 2006 | 01:14 PM
Quik's Avatar
Quik
i think it uses a Kickdown cable for that year. the newer ones are the ones with the TV cable since the older ones use a carb. and i doubt they are anywhere near strong
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
RCS02v6
Sep 29, 2015 01:46 PM
wraith777
Sep 28, 2015 10:49 AM
