1.7's ......
Old Mar 19, 2006 | 12:12 AM
90lxrider's Avatar
90lxrider
Default 1.7's ......
so check this out....i ordered these proform 1.7rr from jegs b/c the crane's were on back order and i figured that they would b a direct bolt on .....but they arent.. i have to buy longer pushrods..
now is anyone runnin the crane rr and if so r they a direct bolt on.. b/c if they r i will send these proforms back and spend the extra 20 bucks and wait for the cranes...so if they work with stock pushrods and everything else stock lemme no please ASAP
all stock internals btw
Old Mar 19, 2006 | 01:07 AM
wildcobrar's Avatar
wildcobrar
Default RE: 1.7's ......
The crane bolt down roller rockers come with the Ford part number right on them. (1.7) and they are the exact ones from Ford Racing know as the Cobra rockers. I have used them on three different builds with the stock heads without trouble. I have had to go longer push rods on aftermarket heads because the are usually slightly taller than the stock head making the push rod too short.
Old Mar 19, 2006 | 02:22 AM
OnyxCobra's Avatar
OnyxCobra
ORIGINAL: wildcobrar
what specifid heads have you had to get longer pushrods with?
Old Mar 19, 2006 | 05:16 AM
Liquid_02's Avatar
Liquid_02
You might have to grind down your valve covers as well, sometimes with the stock valve covers the higher rocker has a tendancy to hit the cover, quick and easy fix though since they aren't just cheap pressed valve covers like most cars have, lots of material to grind.
Old Mar 19, 2006 | 12:22 PM
90lxrider's Avatar
90lxrider
so i should send the proforms back and get these crane cam energizers 1.7's from JEGs..?!?
Old Mar 19, 2006 | 03:05 PM
90lxrider's Avatar
90lxrider
anymore help......????anyone....
Old Mar 19, 2006 | 03:33 PM
marx91's Avatar
marx91
ORIGINAL: 90lxrider
i have a set of the cranes from summit, and i used my stock pushrods and havent had any problems
as posted above they are the same thing thats on a '93 cobra
Old Mar 19, 2006 | 06:58 PM
90lxrider's Avatar
90lxrider
alrite one last time ...im going to send my 1.7s back and exchange them with the crane cam energizers vaccuum die cast 1.7's
i need to know that the crane cams RR will be 100% bolt on w/ out new pushrods or anything else ..
sry. bout all the msg's but i dont want to re-order the wrong stuff....please help this broke back yard wrencher....
Old Mar 19, 2006 | 06:59 PM
90lxrider's Avatar
90lxrider
o yea i have stock heads and stock everything else
Old Mar 19, 2006 | 09:31 PM
90lxrider's Avatar
90lxrider
c'mon now guys ..point me in the rite direction....please
