Something hard to answer
Old Mar 20, 2006 | 02:02 AM
  #21
BlueDemon's Avatar
BlueDemon
Default RE: Something hard to answer
dah how many licks does it take to get to the center of a tootsie roll pop????????????
  #22
ikeybmg's Avatar
ikeybmg
but if he could chuck it i bet hed chuck da h@ll out of it!
Old Mar 20, 2006 | 02:03 AM
  #23
ikeybmg's Avatar
ikeybmg
ihave mine at 900 warm and its around 800 when i first start it.
ORIGINAL: grabbem88
you mean 900 when first started?
ORIGINAL: Tims 88GT
ok whats your tps set at? with you cam you may have to run 900 base when warm for it to idle cold. mine is 900 warm
  #24
Tims 88GT's Avatar
Tims 88GT
no fire the car up let it warm up, then set you base idle to 900, make sure the screws on the tps are loose, then turn the car off and set the tps to no lower than .985
Old Mar 20, 2006 | 02:04 AM
  #25
Black Snake's Avatar
Black Snake
I got one, will a Tranny for a Newer 4.6 bolt up to the 5.0?
Old Mar 20, 2006 | 02:05 AM
  #26
grabbem88's Avatar
grabbem88
well when cold it takes awhile till it catches else it's 500rpm
Old Mar 20, 2006 | 02:08 AM
  #27
Tims 88GT's Avatar
Tims 88GT
how old is the iac?
Old Mar 20, 2006 | 02:09 AM
  #28
grabbem88's Avatar
grabbem88
newish?..hell it's probably 18yrs old?...i didn't clean it when i reistalled it
Old Mar 20, 2006 | 02:14 AM
  #29
Tims 88GT's Avatar
Tims 88GT
most of the time cleaning the iac makes no diff, i replace mine, its so much hassel tryng to clean it, so that may have a lot to do with it. most of the time if you take the car somewhere and say it will not idle they tell you that you have to replace the iac on the spot.
Old Mar 20, 2006 | 06:50 PM
  #30
grabbem88's Avatar
grabbem88
yeah,but it worked fine before tear down...
