Grinding every gear. Help
theres 2 plugs on the passanger side of the tranny, the top one is to check, the fluid should be level with the botum of the plug threads, and the botum plug is to drain it.
ORIGINAL: RawGtPower
I know this sounds stupid, but how do i do that on a 5 speed. Also, how would i go about changing the fluids?
what about putting the fluids through the top where the shifter comes off, ever since i've had my car thats were ive been told to put the fluid in. it'ss on my 92gt t-5, ive only done this twice since i've had the car goin on about 1 1/2 and i havent had any problems. am i supposed to do it like that or no.
Ive had the car for a year now and the guy said he had a stage 2 racing clutch installed into it. I believe it because the pedal is very stiff when engaging. As for free play, not much
its never done this before though, and the only time it doesnt grind gears, is when i actually do ride the clutch. If i drive it normally now, then its just going to grind every gear i go into.
My steeda kit is sitting in my pile o' parts waiting to go in...
