2 questions...for now anyway
1. My heat blows, but hardly warm, do you think its my heater core? Should I try flushing it before replacing it if that's the case?
2. My EGR's been pulled, what do I do to make the check engine light turn off? |
RE: 2 questions...for now anyway
um for number 1 check the vacuum lines and for numbre two you may need MIL delete or something like that.
TTT
flushing the coolant wont help the heat come out, just bypass it for now then replace it when you can
If it's not blowing hot air it could be either the core is clogged or the heater switch has quit working.
As for the check engine light, you may have to do like Crazyfast50stang said and install mils |
Question 1:
If it's blowing air hard but no heat, then i agree with 1990mustanggt, in which case if the heater core is clogged, i've heard of people switching the order of the heater hoses, so that the hose pumping coolant in is now on the outlet side of the core, do this while flushing motor, so that you dont' just recirculate all that crap through motor Question 2: I bought one of these... http://cgi.ebay.com/ebaymotors/87-95...50685284QQrdZ1 Worked fine |
Just take off the heater core hoses and put a garden hose up to one and put some pressure through it, see if you're getting a good amount of flow out the other end, if you're not getting much, just keep shooting water through it and it should eventually un-clog.
That fake egr thing should probaly do the trick, is that the only way?
And I figured I should flush the core, I heard sometimes when you do a motor swap it can get crap in it. I should be doing it tomorrow, I'll let you know |
is your car having trouble warming up? it may or may not be the thermostat, if its stuck closed the engine will not warm up and you wont get any heat.
actually my temp guage acts pretty weird, in that it doesn't work most of the time. It seems to stick, i caught it working a few times, but other then that it moves a little and just stops. But it doesn't seem to not warm up.
