TW head question
Apr 2, 2006 | 12:34 AM
TW head question
Ok serious question for the night, What is the most lift and duration you can run with a stock bottom end and Trick Flow TW heads?
Apr 2, 2006 | 12:39 AM
RE: TW head question
[sm=bangbang.gif][sm=signs006.gif][sm=smiley35.gif]
Apr 2, 2006 | 12:40 AM
is this the specks for trick flow stage 1 cam? 221°/225° .312/.319 .499/.510 112°
Apr 2, 2006 | 01:14 AM
Apr 2, 2006 | 01:20 AM
so .600 lift with track heat?? that not right
Apr 2, 2006 | 01:48 AM
The lift maybe limited by the clearance between the retainer bottom and the valve guide top.......
Apr 2, 2006 | 01:51 AM
could be, i think im ok .522 is not that much really. ill call the MF'er's
Apr 2, 2006 | 01:19 PM
Quote:
ORIGINAL: tinman
This is true, I was only providing the TF piston clearance info. The cam I am running pretty much puts the springs solid at full lift.
Apr 2, 2006 | 01:45 PM
But is your bottom end stock? what are your spec?
Apr 2, 2006 | 02:21 PM
Quote:
ORIGINAL: Tims 88GT
No not stock. I have dished pistons with reliefs for SC.
