Headers?
yea i doubt it's cracked... like tim said i think it's a gasket. crank your engine and put your hands near (but don't burn yuourself) and see if you feel air down there.
also the flange on the header maybe warped from the factory
if it is the gasket use a copper one
i thought it felt a bit soft after i did mine..... makes sense tho.
ORIGINAL: Tims 88GT
i dont think they are cracked, you prolly need new gaskets. you will loose more power than you will gain with bigger headers on a stock motor.
ORIGINAL: Tims 88GT
you won't really loose power you just won't see a huge gain as advertised.
shorties unequal will give you more torque and less HP
shorties equal will give you more HP and less torque
if you use long tube headers then you might loose a lot of torque and may even loose some horse power
but keep in mind this gain will minimal like 1-3
ORIGINAL: RawGtPower
Anything bigger and better than stock will always be an improvement. The more the engine can breath, the better. Air velocity will control weather you get more horsepower gain or not.
