Clutch cable replacement
Old Apr 11, 2006 | 02:52 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default Clutch cable replacement
Whose done it? Factory cable, not aftermarket. Any tricks? Your turn to help me out !LOL! I'm a big boy so would it be any easier if I took out the drivers seat?
Old Apr 11, 2006 | 02:55 PM
primetime5.0's Avatar
primetime5.0
Default RE: Clutch cable replacement
im running a Summit cable no adjuster, and its lasted a while, I previously had a BBK cable and Adjuster and it only lasted a few years.. Its really simple to do, hook the cable under the dash first and make sure someone below has it so it doesnt fall off
Old Apr 11, 2006 | 05:04 PM
gspfunk's Avatar
gspfunk
That's funny...I'm doing mine tonight! I'll let you know.
Old Apr 11, 2006 | 05:10 PM
FoMoCo's Avatar
FoMoCo
I had a problem hooking it to the fork. But i guess it's easier if someone helps you.
Old Apr 11, 2006 | 07:03 PM
Grimace5.0's Avatar
Grimace5.0
I ♥ Acer
Take the drivers seat out.
Old Apr 11, 2006 | 08:28 PM
87FiveO's Avatar
87FiveO
takes me 20minutes if that
Old Apr 11, 2006 | 08:31 PM
white93 GT's Avatar
white93 GT
hook it up to the clutch fork first then hook it up to the quadrant. using the self adjuster in stock quadrants you can rotate it and easily slide on the cable. very simple 15min thing
Old Apr 11, 2006 | 08:59 PM
Tims 88GT's Avatar
Tims 88GT
im a lil guy so i can leave the seat in, but if your a bigger guy ur gonna want to take it out. lil hands help to. one trick is to put the top on then put the bottom on. its an easy job if u have 2 pplz.
Old Apr 11, 2006 | 09:10 PM
white93 GT's Avatar
white93 GT
you dont need two people to do it. its very very easy to do the bottom first then go to the clutch quadrant under the dash.
Old Apr 11, 2006 | 09:16 PM
Tims 88GT's Avatar
Tims 88GT
if u say so, i could not get it that way, good luck
5.0muscle
Jan 11, 2016 01:17 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
Emblazoned
Sep 3, 2015 10:45 PM
