Engine Problem-need some help..plz!!
Old Apr 12, 2006 | 12:50 AM
ScottY94GT's Avatar
ScottY94GT
Default Engine Problem-need some help..plz!!
i have a 94 GT. 145,500 miles....not sure whats up with it lately its been stutterin bad at all rpm's. gets even worse goin up hills . Cleaned my filter, no improvement. Its a bad stutter, its gettin to the point where its jerking the car and the tachometer is jumping almost 400rpm around the rpm its supposed to be at. Is my engine goin dead, did i drop a cylinder, is it just timing, or what?.....there is no smoke coming from the car.
Old Apr 12, 2006 | 12:53 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: I think I have a problem?
How long has it been for a tune-up? Have you pulled a plug to see what it looks lke?
Old Apr 12, 2006 | 12:58 AM
ScottY94GT's Avatar
ScottY94GT
Been awhile on the tune-up...replaced plugs less than 8 months ago!
[IMG]local://upfiles/34056/3A3734CBC904410593DAFC9750101149.jpg[/IMG]
Old Apr 12, 2006 | 01:03 AM
93BlackNotch's Avatar
93BlackNotch
How about the wires? My car ran like a Civic for a few days, I put a set of Livewires on it and it's great now
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Does it miss @ idle? What about the fuel filter, how old?
Old Apr 12, 2006 | 01:14 AM
ScottY94GT's Avatar
ScottY94GT
Repaced fuel filter 2 weeks ago!....my wires, i noticed this last weekend that 1 of the wires mysteriously had a piece of the rubber coating missing...but the integrity of the wire is fine (I think)...the mesh on the inside of the rubber is not frayed at all....could this be my problem?
Old Apr 12, 2006 | 11:27 AM
ScottY94GT's Avatar
ScottY94GT
Any Help with this matter would be much appreciated!
Old Apr 12, 2006 | 11:29 AM
chath_brick's Avatar
chath_brick
maybe your fuel pump is going bad?
Old Apr 12, 2006 | 10:08 PM
ScottY94GT's Avatar
ScottY94GT
Default RE: Engine Problem-need some help..plz!!
Any Suggestion?
Old Apr 12, 2006 | 11:18 PM
Joel5.0's Avatar
Joel5.0
Check the procedures to run the KOEO/KOER/Cylinder Balance self-tests...suggest you run them, specially the Cyl. Bal. test....it will help you id which cylinder(s) have a missing problem, and confirm if the plug cable you have with the rubber coating missing, could be a cause for the problem, or not. GL
