Need Help
Old Apr 12, 2006 | 11:17 PM
95RedStangGT's Avatar
95RedStangGT
Default Need Help
I wanna make my 95 GT faster. How much would it cost to get 3.73's installed for everything? Are the chips they make for the 94-95's worth it? and i have an h pipe and cat back would headers make a big difference? are there any other cheap and easy mods that make a big difference?
Old Apr 13, 2006 | 12:42 PM
gspfunk's Avatar
gspfunk
Default RE: Need Help
ORIGINAL: 95RedStangGT
1--How much would it cost to get 3.73's installed for everything?
2--Are the chips they make for the 94-95's worth it?
3--and i have an h pipe and cat back would headers make a big difference?
4--are there any other cheap and easy mods that make a big difference?
What are your current mods?
1--A gear install shouldn't be more than $400 including gears.
2--Don't get a chip...wait till you're done w/ your mods and get it dyno tuned. They will tune it for your exact mods and straighten your A/F ratio. And it costs less.
3--Headers would help a little, but not much on a mostly stock car like yours, but they'd set you up for future mods.
4--Bump your timing up to ~12-13 (depends on car). Remove the air silencer (pass. side fenderwell) and get a CAI or K&N filter. Get a 75-76mm MAF--it will open your airflow up some.
Old Apr 13, 2006 | 12:53 PM
Suspect's Avatar
Suspect
gspfunk pretty much covered it.
make sure to do a tune up and get it running right 1st tho. also i know ur looking it to be faster, but check out some brakes. one of my fav mods still today. all that go isnt kool if u cant stop.
Old Apr 13, 2006 | 01:49 PM
Materias's Avatar
Materias
the gears cost around 400-500 including purchasing gears...i don't think a chip is necessary if your just gonna do gears...unless you got some heavy mods, new headers won't do much...
You could get some pulleys
CAI or the k&N just take off air silencer
TB
New Exhuast h-pipe x-pipe w/e with a good muffler and high flow cats
you'll feel a difference and you'll like the new sound of it
