Will it work?
Simple question, simple answer. Stock motor minus cold air. Will edlebrock performer rpm heads and an E cam work? I know MAF *should* be upgraded along with injectors, manifold, etc. But, will the heads and cam work on a stock engine?
with an E cam, the only reason you would need to ugrade your springs, is because of valve float. But valve float wouldnt start until like 6200 rpms. And i dont think you will be running your rpms that high very often.
1:7 would be better. i think that gives a E a .533 lift, something liket hat.
ORIGINAL: jonboy5.0
Yeah Im gettin the fully assembled set. The complete heads have everything but the rockers right? Is the 1.6 a good choice for a roller rocker?
