Broken Shifter
Old Apr 22, 2006 | 03:17 AM
razarr69's Avatar
razarr69
Default Broken Shifter
Tonight I was street racing a little bit and I was jamming the gears pretty hard. Once I was done and just cruising around my shifter was spinning when i turned it. I'm not sure if it was loose or what it was but one of my buddies said it was the pin the bottom of the shifter that possibly broke? What do I gotta do to fix this? It's a 5-speed by the way.
Old Apr 22, 2006 | 03:20 AM
Liquid_02's Avatar
Liquid_02
Default RE: Broken Shifter
Is it just your shift ****?
Old Apr 22, 2006 | 03:27 AM
razarr69's Avatar
razarr69
Seems like it, it still shifts fine and goes into gear and all. The **** just is really loose and spins and can be pulled up and down. You think I broke the threads on the **** or sometnihg?
Old Apr 22, 2006 | 03:30 AM
Liquid_02's Avatar
Liquid_02
try taking it right off, or tightening it all the way down, then take a look inside to see how the threads are, this will also tell you if you have more "severe" problems such as if the shifter is actually broken, obviously the problem will still be there when you take the **** off. If it is broken, you need a new one, get a short throw if it's broken
Old Apr 22, 2006 | 03:34 AM
razarr69's Avatar
razarr69
It almost seems like the threads are stripped. When I try to tighten the **** by hand it grabs a bit then go loose again, so that'd be the threads being ****ed no?
Old Apr 22, 2006 | 03:37 AM
Liquid_02's Avatar
Liquid_02
probably will be then, does your **** pop off easy? take it off and do whatever you were doing to your shifter with the **** off to see if the problems still there, if it's not, easy fix, just need a ****.
Old Apr 22, 2006 | 03:43 AM
razarr69's Avatar
razarr69
I'll take a look tomorrow and holla back...I gotta go get drunk now haha. Thanks for the help.
Old Apr 22, 2006 | 03:54 AM
Liquid_02's Avatar
Liquid_02
haha nice, coincidence, me too, friend's holding a party yo
Old Apr 22, 2006 | 03:58 AM
razarr69's Avatar
razarr69
I'm just going to drink some beers at my buddies place and play some street hockey and watch the Stanley Cup playoffs.
firehorse02
Nov 16, 2015 11:28 AM
Explosive
Oct 2, 2015 07:45 AM
guitarman376
Sep 30, 2015 05:54 PM
junior04
Sep 28, 2015 10:53 AM
Sep 25, 2015 06:58 PM
