starter
Old Apr 22, 2006 | 08:09 PM
xtturbo's Avatar
xtturbo
Default starter
i have a question, hopefully someone can help....i have a 86 LX 5.0 brand new motor...when i go to start it, sometimes the starter wont disengage when it starts...tuff too shut off too...what should i change?
Old Apr 22, 2006 | 08:12 PM
Black Snake's Avatar
Black Snake
Default RE: starter
Solenoid, your starter solenoid might be bad.
Old Apr 22, 2006 | 08:13 PM
xtturbo's Avatar
xtturbo
Default RE: starter
i replaced that about 2 months ago...but i guess it could of went bad???? is it possible the starter might be bad??
Old Apr 23, 2006 | 03:40 AM
Black Snake
Default RE: starter
Possible, it might not be retracting all the way so its still spinning when the flywheel spins.
just get a new starter its only 50 bucks from autozone.
Old Apr 23, 2006 | 03:42 AM
Krusher's Avatar
Krusher
Default RE: starter
a lot of problems come from having flywheel teeth that are just slightly ground catching and holding starter teeth that are old... replace your starter in it's entirety and in the process make sure that your flywheel teeth are in good condition... if they are not it might be a good time to change your flywheel/clutch disc/pressure plate/throw out/pilot...
Old Apr 23, 2006 | 03:50 AM
Tims 88GT's Avatar
Tims 88GT
Default RE: starter
i vote starter
Old Apr 23, 2006 | 03:52 AM
ikeybmg's Avatar
ikeybmg
Default RE: starter
+1 starter
ORIGINAL: Tims 88GT
i vote starter
Old Apr 23, 2006 | 12:27 PM
xtturbo's Avatar
xtturbo
Default RE: starter
thanks for the help guys...but i have all brand new ...starter, king cobra clutch with a ford racing 10.5 fly wheel
Old Apr 23, 2006 | 12:55 PM
ttoppedaerocoupe's Avatar
ttoppedaerocoupe
Default RE: starter
did you shim the starter? maybe the bendix is binding on the flywheel and not letting it release, just a thought.
alex
Old Apr 23, 2006 | 01:12 PM
Tims 88GT's Avatar
Tims 88GT
Default RE: starter
Yea thats your problem. Or your ignition switch is not letting go.
