engine setup guesstimates?
What numbers do you guys think this will put out at the flywheel?
Coast High Performance 331 stroker (all forged internals, balanced, and blueprinted)
Trickflow CNC Ported Twisted Wedge heads (65 cc combust. chamber, 185cc/66cc Runners, 2.02"/1.60" valves)
Holley Systemax II Intake (ported to match an 80 mm Throttle Body)
BBK 75 mm throttle body and EGR spacer
C&L 76 mm MAF
Ford Racing 24 lbs/hr injectors
Aeromotive Fuel Rails and Fuel Pressure Regulator
Ford Racing F303 cam (Duration @ .050 226degrees/226degrees .512"/.512" lift
BBK Underdrive pulleys (water pump and crank pulleys only, smaller alternator pulley, with air conditioning, no smog pump)
BBK Equal Length Hedders
I dont know what else to add to this list. I'm just looking for a rough estimate of what you guys may think. Any opinions !?
C&L 76 mm MAF
fastbackford351
Sep 12, 2015 09:42 AM
mungodrums
Suspension
Sep 7, 2015 07:22 PM
