smog pump?
Old Apr 27, 2006 | 03:14 AM
liketoskate1's Avatar
liketoskate1
Default smog pump?
what does it do and what are the gains from losin it and will my car still pass smog in cali w/o it?
Old Apr 27, 2006 | 03:16 AM
Twister's Avatar
Twister
Default RE: smog pump?
it helps pump air from the heads to the cats to light unburnt fuel, it robs 2-3 hp, and your car will not pass smog
Old Apr 27, 2006 | 03:18 AM
liketoskate1
thanx
FiveLiterRiceEater's Avatar
FiveLiterRiceEater
basically, your AIR pump injects oxygen into the exhaust to reduce hydrocarbons. this creates an oxygen rich air that helps combust the unburned hydrocarbons. Living in california, you wouldnt be able to pass an emissions test with it off the car. california is way to strict on this, so i think you're out of luck. sorry
ikeybmg's Avatar
ikeybmg
itll never pass. better hang on to it.
settled4automatic's Avatar
settled4automatic
i've heard you will not pass smog without it. i'm from illinois tho. you might see a couple horsepower gain from bypassing it with a shortbelt. i removed my pump and all of the components, because i like the cleaner engine bay without all that.
Old Apr 27, 2006 | 03:22 AM
FiveLiterRiceEater
im going to turn mine into a evac pump. ...if i can figure the damn thing out.
Old Apr 27, 2006 | 03:24 AM
settled4automatic
mine's an awesome paperweight now
Old Apr 27, 2006 | 10:59 AM
ROTTITANK's Avatar
ROTTITANK
I passed in md with out it.
Old Apr 27, 2006 | 11:47 AM
anthonydalrymple's Avatar
anthonydalrymple
ORIGINAL: ROTTITANK
It is possible to pass the "sniffer"\tailpipe test without a smog pump, (5.0's have been known to run clean enough without 'em), but out here in California you absolutely would fail the "visual" part of the test. The smog tech is required to visually confirm all smog equiptment is in it's proper location.
FYI, i smogged my car 2 days ago. He kinda looked in the engine compartment & really didn't seem to care all that much about the "visual" part.... He seemed to only care about what was comming out the tailpipes...... Of course this guy is going to continue getting my buisness....
