5-lug conversion
Old Apr 28, 2006 | 02:58 AM
50mustangoutlaw's Avatar
50mustangoutlaw
Default 5-lug conversion
i need some help on what i need to make my ride into a 5-lug coversion.can you help me?
Old Apr 28, 2006 | 03:19 AM
FiveLiterRiceEater's Avatar
FiveLiterRiceEater
Default RE: 5-lug conversion
theres mulitple ways you can convert to 5 lug. the differences are on the front end.
for the rear you will definatly need 5 lug axles and drums.
for the front you can buy a direct replacement 5 lug rotor and i believe thats all you'd need.
i think mustangsunlimited.com has a bunch of stuff to do it
Old Apr 28, 2006 | 03:28 AM
5.0 MPG's Avatar
5.0 MPG
The new issue of 5.0 Magazine has a good article on this. I was checking it out at autgozone the other day.
Old Apr 28, 2006 | 03:30 AM
primetime5.0's Avatar
primetime5.0
just buying rotors will only work with a few wheels trust me.... im doing a full sn95 brake swap. Let me know if you have any questions
Old Apr 28, 2006 | 03:38 AM
Liquid_02's Avatar
Liquid_02
Ok, here's what you need:
REAR:
Two DRIVER side axels off a 83-92 4cyl or 3.0L Ranger or Bronco II, or two passenger side axels off a 86-97 Aerostar. You'll need the drums off one of them aswell.
FRONT:
Rotors off a 86-91 Lincoln Mark VII
***Depending on wheels***
I put bullits on mine so I had to get half inch wheel spacers because of the center hub on the rotors is too long, which meant buying new bolts too, bought 3 inch Moroso bolts for 30 bucks and just cut off the tapered end (I have closed lug nuts) and created my own taper.
'Tis all...
And here's what it looks like... And yes, I know my car's missing a few parts aha
Old Apr 28, 2006 | 03:47 AM
primetime5.0
i wasnt brave enough to put a spacer on the front wheels of my car.. also you can use svo rotors
Old Apr 28, 2006 | 03:54 AM
Liquid_02's Avatar
Liquid_02
ORIGINAL: primetime5.0
No torque on the front wheels so it won't be a problem, the rear or the otherhand, wouldn't dare.
Old Apr 28, 2006 | 11:19 AM
SPE926's Avatar
SPE926
i am using rear svo brakes on mine. they are stronger than the sn95 units and are better breaks. I also know that the lincoln that a 86-91 Lincoln Mark VII has the same rear brakes (5 lug disk) as the svo and that you can use those
Old Apr 28, 2006 | 12:59 PM
r.barn's Avatar
r.barn
www.50resto.com
they have a simple rotor and drum kit w/ new axles for about $500 give or take
or
they have a full '93 Cobra full disk brake kit for about $2,000
Old Apr 28, 2006 | 02:19 PM
88BlueGT's Avatar
88BlueGT
LIQUID!!! Your can looks just like mine! lol haha gotta love it.
Why dont you just buy a conversion kit from 50resto.com?
HRnB
GT350 S550 Tech
Dec 18, 2015 09:35 AM
Nov 10, 2015 11:39 AM
DCole24
Sep 11, 2015 10:50 AM
YoungStangsMan
Sep 5, 2015 07:01 PM
