bleeding brakes
Old May 8, 2006 | 04:51 PM
ckyguy68's Avatar
ckyguy68
Default bleeding brakes
i need to bleed my brakes... any suggestions on doing it?
Old May 8, 2006 | 04:55 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: bleeding brakes
Start at the r/r wheel, then l/r, r/f, and l/f. Make sure there are no air bubbles after a few cycles from each wheel and move to the next one. Keep the m/c full through out the process.
Old May 8, 2006 | 05:03 PM
Black Snake's Avatar
Black Snake
Use a vacum bleeder.
Or just take it to Midas or BrakeMasters it only like 30 bucks.
Old May 8, 2006 | 05:05 PM
ckyguy68's Avatar
ckyguy68
should i leave the cap on the M/C?
ORIGINAL: PRO50SC
Old May 8, 2006 | 05:17 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Either way.
Old May 8, 2006 | 05:19 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
ORIGINAL: ckyguy68
ORIGINAL: PRO50SC
no....
Old May 8, 2006 | 05:26 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
I usually take a new bottle of brake fluid, poke 2 small holes in the foil seal, turn it upside down in the reservoir and leave it while I'm doing the bleed. It won't over flow and the m/c won't run dry. Neat little trick I learned over the years.
Old May 8, 2006 | 09:03 PM
ckyguy68's Avatar
ckyguy68
****! the bleeder valve snapped right off! what now?!
Old May 8, 2006 | 09:22 PM
ckyguy68's Avatar
ckyguy68
anyone?
Old May 8, 2006 | 10:30 PM
AdderMk2's Avatar
AdderMk2
Banned
time for a new caliper or wheel cylinder... depends on which wheel yu were working on
