engine code 332.....
Old May 9, 2006 | 09:51 PM
94ford5liter's Avatar
94ford5liter
Default engine code 332.....
My car keeps bringing up the problem code 332 which means insufficient egr flow detected. I don't understand it because the valve is new, the sensor is new, and the pipe going into it is new. I'm guessing the vacuum line going into it is not working. So it must be the line or the solenoid that gives it vacuum. Does anyone know what the specific name of that solenoid is?
Old May 9, 2006 | 11:20 PM
black89gt's Avatar
black89gt
Default RE: engine code 332.....
hmm mines always popped up randomly.. but it came up with o2 sensor codes
Old May 23, 2006 | 12:06 PM
Sup3r52man's Avatar
Sup3r52man
Just recently 332 has popped on up mine as well along with a 565. I removed the egr, cleaned and tested it all seems fine. My next step is going to be checking/replacing the EGR Vacuum Solenoid. Seeing as the parts are fairly inexpensive and im certain they haven't been replaced since the birth of my vehicle i'm most likely going to replace the egr and vacuum solenoid and hope that it solves the problem.
Old May 23, 2006 | 12:08 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
It's called the egr solenoid Also, the port where the valve bolts up could be clogged. Seen that many times.
Old May 23, 2006 | 06:32 PM
Sup3r52man's Avatar
Sup3r52man
After checking the Purge Valve I noticed the vacuum hoses werent up to par. Cracking and such, noticed a big gapping hole as well, so I replaced the hoses and with wishful thinking was hoping that solved the check engine light problem. Drove to work, no light, no light, bam check engine light. Ill have to do more investigating when I get home.
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
zanemoseley
Sep 6, 2015 12:58 PM
zachary1988
Sep 4, 2015 03:04 PM
