Speedometer Readings Off!
Old May 10, 2006 | 08:31 PM
hatch302's Avatar
hatch302
Default Speedometer Readings Off!
Hey, does anyone know if they even have a speedometer gear that matches up for ford racing 4.10 gears? I talked to the local Ford dealership and they say that the only one that can come close to the correct speedo gear is for the 3.73. I've heard that there is one for 4.10s though...just want to see if what I've heard is right or not. Seems hard to believe that they wouldn't seeing how popular 4.10s are...
Old May 11, 2006 | 09:48 AM
Boss_Hotrod's Avatar
Boss_Hotrod
Default RE: Speedometer Readings Off!
They make one but I believe you have to go into the tranny and take off the yellow speedo drive gear and replace it with a different one. I think 5.0 Resto might have a little bit more info about it.
Old May 11, 2006 | 09:52 AM
ncksnapper's Avatar
ncksnapper
23 spline gear i have one in mine, you have to do what hotrod said pull the gear out the tranny, which is easy and switch it which is also easy
Old May 11, 2006 | 03:06 PM
hatch302's Avatar
hatch302
ah ok! hey, thanks a lot guys. [8D]
Old May 11, 2006 | 03:51 PM
ZoSo15's Avatar
ZoSo15
the 23 tooth won't correct it enough. you have to replace the drive gear in the tranny also because anything bigger than a 23 tooth won't fit. however the 23 tooth will be pretty close and all you have to do is buy taller tires.
Old May 12, 2006 | 12:01 PM
ncksnapper's Avatar
ncksnapper
mine is 2mph off so yeah its close enough if you ask me, i have 235/60/15s on the back stock is 225 60 15 so i think that helps it a little like you said
Old May 12, 2006 | 12:09 PM
92hatchLX's Avatar
92hatchLX
How accurate can I get with a 3.90 gear and a 92 AOD. What correction gear would be the best for me? How accurate will it be?
Old May 12, 2006 | 12:13 PM
turt's Avatar
turt
ahhhhhhh.... who cares if its off!!!!!!! look next you......if your getting beat your not going fast enough.
chrisdbassplayer
Oct 13, 2015 06:53 PM
Dathan
Oct 5, 2015 05:52 AM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
Sep 25, 2015 06:58 PM
Sep 25, 2015 06:42 PM
