ANOTHER PROBLEM
I recently bought and installed a used fluidyne attached to a black magic fan and i installed it and the fan will not turn on any suggestions i have the hot wire hooke to the starter and the other wire grounded any suggestions would help alot.
ORIGINAL: turt
yea starter for FORDS are only HOT when cranking it. the solinoid will be a better spot(the large post that goes to the Batt.)
ORIGINAL: PRO50SC
Yeah but then it would have constant power and run all the time. Def needs a relay to control it from a switch.
ORIGINAL: turt
ORIGINAL: turt
yup yup... i was just sayn for motor testing purposes(jump test). But switch to relay to fan is the safest way for permanent setup.
ORIGINAL: PRO50SC
ORIGINAL: turt
stangin1996gt
Sep 21, 2015 11:01 AM
