4 BBL Intake?
Old Apr 8, 2004 | 08:24 AM
Maddog11's Avatar
Maddog11
Default 4 BBL Intake?
I came across a 4 BBL intake (still had a holley carb on it) the other day in the local wrecking yard with the following 1,5,4,2,6,3,7,8 firing order on it. What I was wondering was, if it is a 351 intake would it still fit a 302? Any help would be great!!!!
Old Apr 8, 2004 | 10:31 AM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
Default RE: 4 BBL Intake?
Thats the H.O firing order i belive.
And yes it will fit a 302-351.
I have an 85 H.O holley intake and 650 dual feed sitting on the shelf in the garage ill look and see i think it has the same firing order.
Old Apr 8, 2004 | 11:04 AM
arcane73's Avatar
arcane73
I'm afraid I'll have to disagree with you GMK......I'm almost 100% postive an intake will not swap between a 351 and 302. The 302 intakes are skinnier as far as width is concerned.
Old Apr 8, 2004 | 03:57 PM
86HOGT's Avatar
86HOGT
I think he was pertaining to the fact that the firing order is the same.
Old Apr 8, 2004 | 06:07 PM
TheGmKiller331
I ♥ Acer
Yes an H.O firing order is the same as a 351's.
I must not have been real clear.
Old Apr 8, 2004 | 07:09 PM
arcane73's Avatar
arcane73
My bad.....It was early and my coffee wasn't ready yet. [&:]
Old Apr 9, 2004 | 09:59 AM
Maddog11's Avatar
Maddog11
So now the question is how to tell the two apart... From what I can find the differences are.... 1. Width = 302 is 9.5" - 351 is 10.5" or 11".... 2. 302 has 12 bolt holes - older 351 have 16 bolt holes.... Is this information correct? Also, is there any other ways to tell them apart? Thanks for the help!!!!!
Old Apr 9, 2004 | 01:37 PM
roundman's Avatar
roundman
the firing order you listed is for a standard output 5.0/302, not the 5.0 HO which shares the same order as the 351. (1-3-7-2-6-5-4-8) the taller deck height of the 351 will not let you use a 302 intake on it as it will be too narrow to fit properly like somebody already said. what you have is definitely a 302 only intake.
Old Apr 9, 2004 | 05:03 PM
Maddog11's Avatar
Maddog11
Thanks for the information, so now my question is it worth picking up for about $10 or so from the wrecker?
Old Apr 10, 2004 | 12:31 PM
roundman's Avatar
roundman
the carb alone ougth to be worth $10, it's up to you!
