Timing??
Old May 21, 2006 | 04:32 AM
BlackSVTsnake302's Avatar
BlackSVTsnake302
Default Timing??
My freind just bought a timing light so we are going to check it on my car tommarrow, should I advance the timing? If so how much? I was thinking 11 or 12, 10 is stock right? Ive kinda heard bad things that come out of advancing the timing? Is it worth doing it??
Old May 21, 2006 | 04:34 AM
ikeybmg's Avatar
ikeybmg
Default RE: Timing??
yea, id do it. 13 is the max id start with and 92 octane or better. if it pings or anything turn it down some but id say youll b ok with 13. and yea, 10 is stock setting.
Old May 21, 2006 | 04:38 AM
BlackSVTsnake302
Is it really worth it? having to get differnt gas and all that and worring about other stuff going wrong??
Old May 21, 2006 | 04:59 AM
ikeybmg's Avatar
ikeybmg
yea, you dont have to worry about anything except gas really. long as you dont bump it too high. just bump it to like 12 and try 89 in it. it should be fine and youll feel the difference
ORIGINAL: BlackSVTsnake302
Old May 21, 2006 | 05:00 AM
BlackSVTsnake302
any1?? someone has to have advanced their timing on here
Old May 21, 2006 | 05:01 AM
BlackSVTsnake302
really? it makes a real noticable differnce in power? Im going to go with 12, like as much as a differnce as my H pipe made?
Old May 21, 2006 | 05:47 AM
grabbem88's Avatar
grabbem88
i make 280 with 14*,and 308 with 18*....iv'e used 89 and 92 with no pinging
Old May 21, 2006 | 06:38 AM
ikeybmg's Avatar
ikeybmg
youll actually feel this difference. you can even go higher long as it dont ping when you drive it, if so youll need to turn it back some. i run 15.
Old May 21, 2006 | 07:07 AM
w8less's Avatar
w8less
yea i ran 15* with mine also but i am going to have to retard it so i can run my nitrous.
Old May 21, 2006 | 12:26 PM
nitrous_bob's Avatar
nitrous_bob
you can probably go 12* on 87
but you need to see if your leaning out. best way is bump 2* per run at the track starting w/ 10* and use the setting that gives you the highest mph.
more octane = less power w/ identical timing.
you want to add more octane to use the same timing, but eliminate detonation. or to keep from going lean if spraying.
you can also read your plugs.....if you don't hear it, it doesn't mean your not pinging.
read your plugs for detonation
