everything went wrong today??
First I did a normal oil change but the seal stayed in when I took out the filter and so after I filled it up with 40 dollers of overprised oil. (Denmark)... I started it in my driveway and blew all my oil out everywhere. Then stressing I had my friend start it when I got the second seal out and it ran it for about 30 seconds with him reveing it to 1,500 a few times. Damit There was no oil in the motor. To top it off I switched my two back tires and broke my antitheft lugnut and fitting so now only 3 out of 4 are tight in the back. I have the 10 hole original wheel. Is it easy to get this antitheft lug nut and fitting that goes on top??
RE: everything went wrong today??
distracted by my friend and wanted to see if the problem was solved. Very stupied I know. You think everthing is alright. I added almost one liter after and there was no reading still on the dip stick
ORIGINAL: philthy89fifty
it'd be hard to find just one just go to kragen and buy a new set they are like 30$ but why no one is gonna steal some ten holes
