Compression?
Old May 25, 2006 | 03:18 PM
Frebius's Avatar
Frebius
Default Compression?
I am going to run a compression check on my engine. The meter says to pull out all of the plugs and disconnect the coil. Then it says to turn the car over for about 5 cycles. How will the car turn over it all the plugs are out of it?
Old May 25, 2006 | 03:23 PM
P Zero's Avatar
P Zero
Default RE: Compression?
Itll crank pretty fast, watch for the needle on the guage to bounce 5 times, then stop cranking. Note the reading you get and from which cylinder.
-P.
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
bconboy
Sep 21, 2015 12:52 PM
uberstang1
Sep 20, 2015 06:42 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
