installing a cam
Old May 27, 2006 | 02:01 AM
HACKGT350's Avatar
HACKGT350
Default installing a cam
how hard is it to install a cam? what do you have to do other than angle the engine up so it can be taken out and put in what else has to be done?
Old May 27, 2006 | 02:10 AM
myshifter's Avatar
myshifter
I ♥ Acer
Default RE: installing a cam
brand new cam? Solid, solid roller, hydraulic, hydraulic roller? Which type first off. As for removing and replacing, mach up your bolt that is used for the top cam gear and go buy one at the hardware store that is 4 inches long. This way you have control of the cam while your sliding it in. Be VERY careful not to nick the cam bearings on removal and install. Tell me what type of cam and I can tell you more
Old May 27, 2006 | 03:09 AM
primetime5.0's Avatar
primetime5.0
you dont have to angle the engine to get it out
Old May 27, 2006 | 03:15 AM
settled4automatic's Avatar
settled4automatic
ORIGINAL: primetime5.0
yeah i'm purdy sure you just take the radiator and fan out to get the clearance you need. oh and your ac evap core or whatever the hell the thing is in front of the radiator :P
Old May 27, 2006 | 10:14 AM
HACKGT350's Avatar
HACKGT350
its a hydrolic flat tappet
Old May 27, 2006 | 01:31 PM
myshifter's Avatar
myshifter
I ♥ Acer
Im assuming its a new cam, I use comp cams cam lube for break-in, coat all lobes with a liberal amount of break-in lube. Slide the cam in, put lifters in, timing chain and so forth. Get everything ready to fire the motor on the first try. Make sure you are ready cause you can't be cranking the motor for 20 minutes trying to get it to start. Once started, immediately bring it up to 2500 rpm for 20 minutes. Once cam is broken in, change oil. Drive car.
Old May 27, 2006 | 01:55 PM
88 rubber eater's Avatar
88 rubber eater
Sorry to be off topic but, myshifter, when is that damn 351 website going to be ready! lol. Is it an information website, or are you selling parts? Or both?
Old May 27, 2006 | 02:13 PM
myshifter's Avatar
myshifter
I ♥ Acer
ORIGINAL: 88 rubber eater
hey hey now, im working on it. I dont put together junk and refuse to rush anything. Trust me when it's done it will be heaven for all 351 enthusiasts.
Old May 27, 2006 | 02:32 PM
88 rubber eater
Sick!!! I really want to do that swap this winter! Think youll be done by them lol, just kiddin man. Good luck, but let me know whe its done!
Old May 27, 2006 | 02:43 PM
myshifter's Avatar
myshifter
I ♥ Acer
im putting an email form on the page now so you can enter your address an i will email everyone when its done, about 1 week till its done
