checking engine codes
Old May 28, 2006 | 08:28 PM
elusive1's Avatar
elusive1
Default checking engine codes
just wondering.. since this is the first time for me doing this on a mustang.. how exactly do you check the engine codes whenever you get a check engine light? i know you need a scanner.. but what type? and where is the connector to plug into?
Old May 28, 2006 | 08:39 PM
Joel5.0's Avatar
Joel5.0
Default RE: checking engine codes
ORIGINAL: elusive1
If you mean an EEC-IV (OBD-I) Mustang, '86-'95 5.0L, all you need is a working CEL, a test light or a VOM, and a paper clip; and follow the procedure at http://www.themustang-net.com/eec.shtml '96-up and '95 3.8L Mustangs are EEC-V (OBD-II) systems....for those you would need an OBD-II scanner. What year is yours?
Old May 28, 2006 | 08:43 PM
sc94gt's Avatar
sc94gt
I think Walmart sells one that shows you the code.
I have one the beeps the codes... kind of pain, but works.
You plug into the diagnostic test connector... mine is clipped on the back of the area in the photo.
Turn the key on, but on don't start the car.
It will run it's test and show you the codes.
[IMG]local://upfiles/7754/E6469B1E0A4644CEA4F0BCE4919C1134.jpg[/IMG]
Old May 28, 2006 | 09:00 PM
elusive1's Avatar
elusive1
it's a '92 and i actually just performed the check thanks to your link Joel5.0. anyways, now i have a code 67.. any of you know what this is by any chance? thanks
Old May 28, 2006 | 09:13 PM
Joel5.0's Avatar
Joel5.0
67 is a neutral switch(clutch pedal or tranny gear switch) or A/C on code....need to make sure A/C is off and tranny is in neutral...if you rerun the KOEO once you take care of those details and 67 repeats....then it'll need some checks. Let us know.
Old May 28, 2006 | 11:56 PM
elusive1's Avatar
elusive1
thanks man. it was actually something to do with the MAF. i'm sure of this because the pipe which connects the MAF to the firewall was loose and half off and must have been sucking in air with fluctuating density and flow. after re-tightening this pipe, the code went away. it was definitely a 67 though..
either way, it was a lesson for me in checking the computer
Old May 29, 2006 | 12:12 AM
Joel5.0's Avatar
Joel5.0
ORIGINAL: elusive1
...FYI:
Code 67: Neutral safety circuit failure or A/C circuit was on during KOER Self-Test.
Now, a code 66: MAF sensor went below 0.4 volts during the last 80 warm-up cycles.
from http://fordfuelinjection.com/index.php?p=47
...may be you counted and additional blink.....lol...glad it was that simple though. Enjoy.
djbigskrilla
Sep 20, 2022 01:04 AM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
drumhedd2005
Aug 13, 2015 09:59 AM
