UPDATE: STUTTERING PROBLEM
Ok, today my problem kept occuring (it was about 85* F). i am thinking it is the TFI coil. The outside temp. cooled off significantly, and started raining. within 5 minutes my car started to run normal again. temp. dropped, engine bay cooled off, coil cooled off?... GRABBEM what do you think?
it will run fine for about 20-60 minutes, depending on the temp. then it pretty much stutters really bad out of a stop in first gear, then some of second. once i get going, it gets a little better but still lacks a significant amount of power and torque.
i'm thinking1..i'm thinking!.....when mine did this...my o2 harness was shot...that's why i asked for you to unplug harness....coolant temp sensor can make you go lean also...try coil yet?...
im going to the 24 hour murrays to pick one up right now! ill get back to you!
ORIGINAL: grabbem88
thats what im going to get... did it come with the bracket? did you notice maybe a minimal gain and better throttle response?
ORIGINAL: 92hatchLX
Go get the blaster TFI coil, it's great.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
Seanam
Oct 4, 2015 10:15 AM
stangin1996gt
Sep 21, 2015 11:01 AM
